Starter removal?
VonYinzer
Over 10,000 Posts
Running a VERY basic wiring setup on my 73 cb500k1. Just enough copper to keep the lights on and the motor running. That said, it will be kickstart only. I have seen some info about drag/race bikes that were kick only with the starters removed to trim weight. How does one go about this. ( other than the obvious, remove the starter... ) Is there anything that needs done to the area in which the starter once lived? Some sort of block off plate for where the drive gear entered the motor?
Dont have a link but check out Mysta2 builds. Very nice machine work there, and also Chris of course. Tim will come thru with a link think this was asked in the 1800 section which seems to be bleeding into the build section.
I'm not familiar with your engine, but as well as the starter motor, you should be able to remove the starter clutch and other internal items....depending on how much of the engine you are willing to disassemble.
Someone has asked the same Q about a TX500 here: http://www.caferacer.net/forums/topic.asp?TOPIC_ID=10187
Good luck with it ;)
OH Oh try dropbars.com its Mysta2 site and he has a 360. I thing all you need to do is remove the starter, the starter chain and sprocket. Then plug the hole up. At least thats how most people do older cbs
Awesome.... Thanks.
