Starter short! Yikes!!
diesel450
"Fast with a past"
DTT BOTM WINNER
So,
I get my '72 350 four running and am fiddling with the choke to get it to idle, it stalls and I hit the starter button to restart it, it does and I continue fiddling. All of a sudden the starter kicks on (while engine is running) and continues to run! I hit the kill switch and the motor stops (i think) but the starter continues to crank, motor is definitely off at this point. I turn off the ignition, starter keeps running, I panic, starter keeps cranking. I run for a screw driver to disonnect the battery starter cranks battery all the way to dead before I can get back to it. While disconnecting the battery I notice that there is smoke coming off the terminals.
I know there is a short or crossed wire somewhere but has anyone run into this before and have any tips?
Scott
Thanks, I had a feeling it was something like that. I think I will just disconnect the starter and run her on the kick start for now. The part I don't get is why once the ignition is off the thing kept cranking. There should be no power to the starter at that point. any thoughts?
Okay, Forgive me. I'm not real familiar with electrical stuff. Did the starter button (on the handle bar) short out? or is it deeper than that? That was sort of what I was thinking. that the connections there got fouled up and sent current through. I thought I might actually remove starter altogether (at least for now)
If you have advice on what on I should do I'm all ears.
Thanks!
Scott
it has nothing to do with the start button on the bars. I am sure the hand controls are fine. If you follow the pos wire from the battery, you will see that it leads directly to the solenoid. The other post on the solenoid leads directly to the starter. Internally the solenoid has fused itself together so now the pos lead runs directly to the starter causing it to run constantly.
I've got a good picture here, thanks. If you happen to have parts That's great. I'm going to take a look at it today and see if I can find the damage and any other dmamge caused. I did check the button (externally) and it does seem to work fine. I'm going to open it up today though and at least clean it.
I did hit the button to restart the bike after a stall. but it did release and the starter went off. the starter then re-engaged later on its own.
Thanks for the insight I will let you know what I find.
I have the same problem on my 360. I was told by an old honda mechanic from back in the day that 90% of thoes problems come from the switch assembly. I have not had time to check mine, but he was fairly confident of what my problems were.
