Starting troubleshooting
DetroitStyle
If it leaks, we can fill it
1971 CB350. Previous owner started and never finished. I'm taking over. Here's a video of it started and running, but this is about all it will do. It doesn't want to rev past about 5k and the left side plug is soaked with gas after just a few minutes. Lotta smoke and unburned fuel coming out of the exhaust.
http://s88.photobucket.com/user/EFWoRKS/media/2012-12-21_13-17-00_748.mp4.html?sort=3&o=2
Previous owner told me that the carbs were completely gone through and this is what he ended up with. He suspected an electrical problem.
Where do I start? Testing coils? caps?
I bought a multimeter and this is my first trip down the electrical road. :o
Check timing. Check timing advance mechanism. Check for timing chain tension. Check for fuel flow, like a pinched or bent fuel line. Check fuel filter.
What does it act like under load, with you riding it?
If you have raw liquid fuel coming out of the exhaust, you definitely have a carburetor issue. Dirt in the float needle, stuck float, or misadjusted float could cause this.
Under load, it won't pull away at low RPMs, just bogs and dies. I have to rev it up to 5k and slip the clutch. For a second or two it feels ok, then it's back to blah
OK, a few things to report. another rough start, belched a lot of smoke, running the same. I took it for a quick ride, same symptoms... Wouldn't really idle, rev and slip to get going, won't pull past 5k and is very slow to do anything. Basically I had to hold about 1/3 throttle and slowly wait for it to get going while feeling like it could sputter and die at any minute..
So, I started by pulling the plugs again and this time, the left plug was white on the tip, crusty around the rim and dry. The right looked good. Tiny bit wet, but pretty normal.
Then I noticed today that the right side petcock wasn't fully turned, possibly causing a fuel issue. So I opened it up, changed both plugs and went for a ride. IMMEDIATE difference. Power, torque, throttle response! It was all there! No need to rev and slip, it pulls fine from the bottom...
... But it still doesn't want to go past 5k and when I pulled the plugs again, both of them were white on the tips
If the battery hasn't been replaced recently, you should have it load tested. Missing in a cylinder is a common low-battery symptom for the early Honda twins. If that load test checks out, I'd check timing and compression before messing with anything else.
Either this isn't true or the PO didn't know what he was doing.
You need to clean the carbs.
I spoke to the PO over the weekend. He told me that the carbs were sonically cleaned and are still at stock settings. With open carbs and exhaust done, I'm pretty sure that this will become a jetting issue? Running out of fuel at 5500rpm? That would seem correct with the white tips on the sparkplugs? Running very lean?
Also, the battery is brand new.
This is a case where the PO built the bike all at once, with new stuff everywhere, so there's a lot to chase. I will still test the battery tomorrow. Kids are at the in-law's for the day and I'll actually have several hours to myself in the garage!
Ignore the carbs for now. Until you're ruled out battery, timing, and compression, they're a red herring.
Messing with fueling before verifying timing and compression is a sure road to a migraine.
OK. I will start out where you suggest. I'm just trying to understand though... what am I looking for in regards to the timing? How would the timing cause these symptoms? (just asking, I know nothing)
If your timing is retarded too far, you lose power because the fuel is still burning when the exhaust valves open. The still-burning mixture is escaping from the cylinders when it should be going toward forcing the pistons downward in the power stroke.
As revs increase, the problems gets worse until there isn't enough compression in the cylinder for the mixture to even ignite (hence the wet plug on one side).
