Steering column/tree lock
Hey guys, I really want to be able to use the tree lock on my bike, however when I stick the key in, it won't work. I don't think it's rusted or anything, or maybe the PO changed the ignition, therefore the key won't lock it. Is there anyway to change the lock to use different keys? Or is there any way to replace it?
What kind of bike?
I took mine off and after realising that it looked like shit, I painted the body of it. I taped up all the electrical contacts and the chrome and just went to town on it with some duplicolour. After re-installing it, the steering lock doesn't work. When you lock the bike, there's a column that shoots out the bottom of the ignition switch housing. The paint I used gave it a nice seal. So...I gotta tab a bit of stripper on the column to free it up.
Take a look at the bottom of your switch housing. Do you see the circular column? Is it rusted to shit? Is it painted over?
If the previous owner replaced the ignition switch and it doesn't have it, you can buy a new one. Grab the number stamped on the tank (if you have a lock) and/or the seat lock and order a matching one. They're not too expensive.
Here's one for an old Goldwing.
I have a 1974 cb450 and the steering lock is found on the bottom tree. I don't think what you posted will work with my setup.
I sprayed pb blaster in there for 3 nights straight. Perhaps it may be rusted beyond belief? Worse comes to worse, I can just throw on a padlock onto one of my spokes or something hahaha.
I don't know shit about 450's. ???
Just make damn sure you remove the lock before you ride away. Perhaps a big Pee-Wee Herman type of chain?
LOL exactly!
There's someone at my college who uses a lock on one of the spokes. It's a more modern cruiser too.
I haven't gone to a locksmith yet..but I really should since I need to see if they can re-key a seat lock for me as well.
I'm definitely going to buy a rotor lock and maybe a pitbull. I can leave it to guard my bike.
dont forget a shotgun too, preferably a 12 gauge, they work great as an anti theft device and anti soliciting device too, i know from experience :D
them survey people have not been back since i opened the door with a shotgun in my hand :D
I have the exact same setup and mine wouldn't work for a while. Once I finally got it in, it continued to work after that with a lot of wiggling around to get the key just right before it would slide in. It looks like you could replace it on mine, but I don't know where you would find one as I have never seen one on ebay. I use my lock regularly now in combination with a lock on the front wheel but it still takes me a good minute or two of wiggling to get it to work.
I'll have to try more wiggling and PB Blaster then. Hopefully that'll work!
Don't know if this will help, but I realized that I don't actually have to wiggle the key to get it in, I have to angle the end of the key more towards the middle of the barrel, putting more pressure on the teeth of the key to get it to slide in properly. Once it is in it work just fine.
