Sterling Throttles
dcwp
Coast to Coast
So I'm looking to buy a new throttle to go on my project bike and I really like the ones at sterlingmotorworks.com
http://sterlingmotorworks.com/throttles?b=1
The problem is that I'm a little confused on the single/double pull thing. I thought single pull meant only one cable coming from the carb, no return cable and double means two cables, pull and push or whatever they're called.
I'm not positive though from these pics
Single:
http://sterlingmotorworks.com/inc/sdetail/1219
Double:
http://sterlingmotorworks.com/inc/sdetail/1220
On the single pull I see a hole for a cable, but what is the bold next to it?
On the double pull, the cable inlets are next to eachother on a different axis than they are on my OEM throttle. Do they both pull the same way or is this the pull/return that I'm looking for?
Actually as I look a little closer, I get the impression that neither is going to work for me. Anybody know where I can find a similar throttle with the push/pull cable setup I need?
thanks
dan
im fairly certain the dual cable is for one cable to each carb. instead of one cable that splits to each carb
Thanks. The more I looked around, the more that seemed to be the case. I didn't realize push-pull wasn't the norm. Anyway I scored a nice one on ebay so I'm all set.
Dan
