colpumpkinnuts
Banned from public transportation
I've found that a cordless dill/driver works very well for removing screws that are almost stripped but still have a bit of a head to them. Start with the clutch set to a very light setting and hold it against the screw head with a lot of pressure, preferably all of your body weight. If the clutch slips, gradually work up the setting on it. If you don't put enough pressure on the driver it will slip and strip the head worse. Of course, this only works if you have something for the bit to grab onto. I've tried an impact driver in the past without much success but had the drill/driver work very well.
