Stupid CB360! I've got 99 Problems and Bad Weather Ain't One
Well I broke down and brought the bike to a local shop, Josh Mott Racing. It started right up for them which was good but the owner could hear right away that the right cylinder wasn't idling. Left it there for a few days and when I picked it up it ran awesome! They said that the motor is really tight and in great shape. They reset the point and timing. Then they took the carbs off. Found that just about all the O-rings were toast, the mains were too small and not seated properly, same story with the pilots, needed bigger needles and the floats weren't installed correctly. Unfortunately, the carb bodies are worn out at the throttle shaft so they were getting some leakage on the right carb. Ended up that the right carb air screw is now about 3/4 of a turn out more than the left in order to compensate for the mystery air leak. But for now, the bike is running great. With all the money I spent on the carbs between PJ and my local shop, I probably just should have picked up a new set of VM30's. Oh well. Lesson learned.
Added some fenders today to make it more rain friendly. Here's a gratuitous shot finally of the finished bike.
There are felt washers on the throttle shaft, usually oiling them will 'cure' leakage problems. If the throttle shaft end plugs are missing you will have a major problem as there is a drilling behind shaft direct to atmosphere (I have no idea why?)
I make new plugs to cover throttle shaft ends.
This is mainly for anyone following thread, pics of parts, pieces and faults
Plug should be just above fuel screw (right side of pic)
end plugs (it's a common 'fault' I'm making several for CB360.com)
End plugs fitted
VM30's are not the cure everyone thinks they are going to be, even 'pre-jetted' they still need work and you still have issues with air stalling in venturi when you open throttle too quick. For racing where rpm rarely if ever drops below 6K they work OK
PJ
I can vouch for CrazyPJ's plugs for the throttle shaft...They fit perfectly, and look fantastic...
Did the shop do compression and leak down tests?
They shouldn't have done anything until that was done
The carbs were synced on my 360, if it wasn't idling on right cylinder there could be a problem, shouldn't have been out far enough to hear it unless something is wrong. Unless someone else has had the carbs apart, they were set up to work right with K&N filters, there are no 'standard' settings and it will be running rich when you check plugs if they re-set float level to stock 19mm.
As for 'O' rings, any that were changed were stock replacements (the only 'O' rings are on float bowl, pilot screw and shut off valve)
The thing that may need changing is secondary main jet, I tell everyone that before they send me carbs. (105~125)
Fitting larger primary mains and shimming needles may 'feel' better but it will foul plugs. (ask Trek97, he's tried all sorts of jet changes on his 360)
You got carbs back with stock primary, 35 pilot and 110 secondary mains
Anyway, if everything is OK, you should be able to cruise around 85mph with at least 100mph top speed (usually closer to 105)
