Stupid Float Question?
Wraith
I took my overflowing CB 360 carbs apart to clean three weeks ago and got sidetracked. :D Which way do the floats go on? Anybody have pics?
Neither way looks right to me and actually the way I took them off looks the most wrong. ???
You mean the floats themselves and not the float needle, right?
There's a little tab that comes off the float arm, that part points towards tthe float needle. Usually there's a little bit of wear on the float arm where the needle has rubbed on it.
only works one direction, gas is permanently off if upside down.
It aint rocket science (not even 'crotch rocket' :D :D)
You know I'd looked at it both ways and it did make slightly more sense one way. :P But to read the instructions on how to set float height the tang never comes off the needle the way they are set now, so that must mean they are set waaay wrong from the PO?
The float is offset from the operating arm, you should be able to see where its soldered together if fitted right.
