Suzuki GS500 engine build.Largest bore(80mm) ever done on a GS500 engine.569cc
ben2go
Two Wheel Projectile
This weekend a member from GStwin forum (Dgyver) and myself restarted building an engine he lost steam on.He gathered the parts a few years ago and did some of the machine work.All that was left was assembling,test,and tune.This is easier said than done tho.The first thing that was done was to press out the GS500 cylinder sleeves.Then the cylinder block was bored out and the 80mm cylinder sleeves were pressed into the GS cylinder block.After all that was completed,the engine case was clearanced to accept the larger cylinders.The GS specs at 487cc.We are pushing displacement to 569cc.The lower end is completely rebuilt by us this weekend.All new bearings and seals.I replaced a bad output shaft that was worn where the sprocket engages the splines.All parts used are Suzuki for the rebuild,except the pistons and cylinders.Neither of us are sure what bike they are from but they share the same dimensions as the GS except being larger in diameter.We do know the pistons are old Wiesco units.The cams are GS500 and reworked by Megacycle cams.Induction is 36mm Mikuni carbs from a GSXR with GSXR boots.The head was ported and polished and came from another member on GStwins.The engine will go in this bike. http://www.dotheton.com/forum/index.php?topic=30047.0 That means this project has been put on hold yet again. http://www.dotheton.com/forum/index.php?topic=30555.0 If this engine holds together through break in,we are going to try out a set of flat slide carbs from a snow mobile.Supposedly,they will help produce instant throttle response and give a better power band.If all this works out,I may follow through with my Microsquirt based fuel injection system.I had this all planned and laid out once, before I became disabled.I will try to get pics up as I can.Because Dgyver lives so far away,it will be a slow build as I can't travel but every other weekend if my health holds out.
Stock=GS500 74mm bore x 56.6mm stroke
Largest Bore Ever Done=80mm bore x 56.6mm stroke
Megacycle Cams=reworked stokers for more lift and duration.We don't have the spec sheet
Modified cam gears to make them adjustable.
Induction 36mm first gen GSXR Mikuni CV carbs with 36mm GSXR intake boots and K&N pod filter AKA lunchbox filter
Copper head gasket cut to fit the larger pistons and cylinders.
Here is where all this started. http://gstwins.com/gsboard/index.php?topic=14401.0
The pistons and cylinders installed into the GS500 cylinder block.
Clearancing the case for the larger cylinders and pistons.
I will post more pics and info as I can get it.We were pressed for time this weekend and I forgot my camera.
