Taillight Integrator Kit
warpedworm
I could agree with you but then we'd both be wrong
Has anybody ever used a taillight integrator that makes a 2 bulb taillight into a turn signal and taillight? Anyone have any experience with the below unit or others if there are others?
I was searching for a taillight for my cafe and found this unit.
Yana Shiki Taillight Integrator Kit, they are anywhere from $40 to $60 depending
on where you buy them.
As an alternative ---- It is basically the same thing as trailer converter box. You should be able to get those cheap at U-Haul. It integrates your turns, brakes and running light signals to the two light setup on a trailer.
Inputs:
1. ground
2. power
3. left turn
4. right turn
5. tail light
6. brake light
Outputs:
1. ground
2. left turn/brake
3. right turn/brake
4. tail light
Each of the two bulbs must be a dual filament type.
