Testing alternator
AgentX
Over 1,000 Posts
Got a Royal Enfield with a permanent-magnet alternator. Got a cheap multi-meter.
Not charging. Battery seems fine. Not sure if it's the Boyer reg/rect/capacitor I have or the alternator; all parts are new.
How can I check the AC output on the alternator?
Been told to check voltage between my two purple wires. (other two are orange and yellow.) Should this be done with the alternator/rectifier connection completely unhooked? (I'm using bullet connectors on the alternator leads, plugged into a multi-connector crimped to the rectifier wire.) Does it matter?
Last time I got it fired up, I checked VAC between the purple wires with all connectors plugged in and only saw 2-9 VAC max; should have 45 or so according to the Enfield guys. Took this to mean the alternator was jacked, but now I think I might have been measuring incorrectly, no?
if its a permanent single phase unit there should be around 50v AC between the wires. When using a meter, be sure to have it set to AC. When it gives you 9v AC, its fried. No doubt.
Let's turn the page back a second.
First, charge the battery fully on a charger.
Second, what is the voltage at the battery terminals with the bike at idle, and then when you rev the engine.
Should be around 12v at idle, and 13-14 when you rev. If it's doing that but the battery isn't charging, your battery is possibly toast. Take it to your local battery shop and they'll test it for you and sell you a new one :)
If you're not getting those voltages, then start digging into your charging system, but cover the easy stuff first. Another even easier test is does the headlight get brighter when you rev the engine. If it does, your charging system is working. It's not a scientific test of how well its working, but if the bike generates more voltage when you rev the engine, it's doing the right things.
Yeah, revving the engine doesn't change the voltage across the battery, which led me to believe it's the alternator or the reg/rect.
The headlamp makes the ammeter dive to max negative and no amount of revving changes that.
When the bike is running, revving does make the needle nudge just a tad towards positive.
Thanks; I just want to make sure I was testing it right before I made the call that it was the alternator. Was using the 200VAC setting, and checked the meter against household VAC to make sure that it was working and I was reading it correctly.
I clipped the test leads to the alternator wires at the base of the bullet connectors which enter the 2-1 crimp connectors on the rectifier leads. I didn't remove them from this connector. Could that cause the low reading?
Should I un-plug then test the wires without them being hooked up to anything else?
No worries...I am generally confused as fuck, so any and all input is appreciated.
Any advice on where/how to test the alternator output? Thanks!
