The issue I am having is when I blip the throttle on my CB 360 the RPM goes up a bit higher than normal and won't go down for 2 or 3 seconds after I release the throttle. Any reasons why this is? I just rebuilt the carburetor.
cable free play adjustment, cable movement ,linkage/spring, airleak.......have you ck'd your timing and aau( auto advance unit) for proper operation also........joe
I have the same issue on my CB450. I believe it is a sticky carb slide or dirty needle. I need to take it apart and clean again to see if that fixes it.
