Tire Pressure
chrisf
Over 1,000 Posts
Hi gents:
After riding my CB360 around for a while now, I am even more aware of how much my CL350 vibrates. I realize that in manifests easier because of the clip-ons, and I'm sure the low gearing contributes to vibration--even at cruising speed.
I may drain the forks well and make sure that I didn't overfill the little guys. My buddy, Sam, also mentioned that I may be running too high of tire pressure. I agree this might contribute to the problem because I shaved a significant amount of weight off this bike; yet I run the tires at their stock pressure.
So what is a good tire pressure range for these little CB/CL350s? I'm running the Avon RoadRiders...
--Cheers, Chris
I can't imagine a pound or two of tire pressure is going to make a lot of difference. If you were running them at 90psi maybe, but at 30psi or whatever stock is, there's plenty of 'give' in the tires already.
Not sure of the technical differences between the engines in the two bikes, but obviously there may be all sorts of little things done to the 360 engine to keep it a little more smooth than the 350, and no amount of suspension changes etc. will fix it.
I'm looking forward to feeling the same on my XS650, which are notorious for vibrations.
