Too Much Smoke!
maxypants
Hey,
Well I just got my T250 tuned up as I did not know how to tune my carbs. Went on a 45 minuet ride to the tattoo shop and it was still smoking the whole way there and back, and not just a little smoke I was leaving a good trail that I could see in my rear views. I know its a two stroke but I didn't think it would be this bad. Do I need to get the carbs looked at again? I was running synthetic two stroke oil from Lordco not to sure the brand, should I use better oil. What should I do to get it to mellow out.
Thanks in advance for the help.
Is your bike equiped with oil injection or is it premix in your fuel?
Regardless, it sounds like your fuel/oil ratio is off.
It has oil injection, I dont mix fuel right into the tank. Do I need to adjust the oil pump? Or what do I do?
If you don't have one, grab a good manual for your bike. It should have procedures for adjusting mixture.
Just sounds like you're running too fat, as well by cleaning up the fuel/oil ratio you can gain a decent amount of horsepower. Be careful not to lean it out too much as you will burn the little thing up.
