Transmission gears
my-79-750-k
Therapy is expensive. Riding is cheap. You decide.
OK, so I hate my fifth gear ratio (0.96:1) It's not much of an overdrive at all. Here's the question, could I grab a 5th gear from another bike and swap it into my transmission? Aside from the different size main shafts, which I'm sure each bike has different sized gear shafts, I can machine those out a bit at work if need be. So would this work?
Of course. But it will need to engage with the gear next door in the same way as teh original and have the selector fork groove in the same place and... You get my drift.
In the case of a Suzuki GT750, some gears from early 8 and 16 valve GSX/GS750 can be swapped in but it's not simple. better solution is to work out the ratio you want and get Oil Tom www.mpe07.co.uk and see what he can manufacture for you. Not cheap but the right way
Well, I already changed the gearing around (Went from 15/38 to a 18/43 {Previous Owner} to 17/39 now). It'll be running about 800 rpm's less than stock gears at highway speed, which is great and all, but I want it to retain the acceleration it has with the gears and just have an actual overdrive, say like .85:1 or something like that. Is there another bike that has a similar trans that would have more of an overdrive 5th that I could swap, without having to do all kinds of crazy custom internal machine work?
you've got to make sure the input and countershaft are the same distance apart as the model you're planing on taking the gears from, and I would only use the pair from the other tranny, don't use a single gear and assume it's the same pitch and thrust angle, it might look like it fits but will destroy itself, that and it's not a great idea to mate used gears from two different sources. secondly, you'll need to make sure the shaft diameters are the same and the engagement dogs are also in the right place and the right number of dogs... so you've got a bit of research ahead of you, chances are if they make an aftermarket upgrade, go for it
