Triple tree removal?? Special tool?
diesel450
"Fast with a past"
DTT BOTM WINNER
How do you take a triple tree apart? does it require a special tool? Looks like it to me on my '72 Yamaha R5. I'm waiting for the manual on this thing to arrive.
Any help?
Is there a thick metal ring piece with notches, because that can usually be taken off with a large flathead screw driver.
Yes, here are some pics. I've got this big gas cap looking thing to deal with as well. Do I turn that thick ring with a screwdriver to loosen the whole thing?
and the underside
If you can get the gas cap off, which I assume is either holding the top triple tree on or covering a bolt and washer that are holding the top triple tree on... Then you will have that thick metal ring with the notches fully exposed and you can put a flathead screw driver against the side of one of the notches trying to be as perpindicular as possible to the ring and pound it off, might want to spray some wd-40 to lubricate the threads before you start, and just take your time and be careful. Also be warned that once that thick metal ring is taken off the lower triple tree will fall right out and all the tiny ball bearings will go everywhere. So when it is very loose try and loosen it by hand while hlding up the lower triple tree to avoid loosing the stearing stem ball bearings. They will be in a race in both the top of the frame neck and in a race in the bottom of the lower triple tree. Once the thick ring is removed you can just slowly lower out the bottom triple tree from the neck of the frame. Good luck.
Uh, yeah, friction steering cap, I knew that. : 8) (I did figure it was something to do with the steering. I tried unscrewing it but its got a retaining clip of sorts. I didn't want to force it. I'll mess with it this weekend.
thanks
Got it. Thanks for the help fellas. Just needed some lube on the threaded end of the cap rod. yup, ball bearings every where. No worries though I'm replacing them any way.
