truck ramp
Blake
the future is my friend
So, I got a truck. Great for moving the bike when I can't ride it. Now I need a ramp. My truck is tall ('04 F-150), and I need something to safely get the bike up in the bed. What do you guys use for ramps? I've used planks of wood in the past to load onto trailers, but I'd like to get something better. I've looked on J.C. Whitney, but I'm sure there are better products out there.
My local Honda dealer sells aluminum ramps with a tailgate lip for about $50.
yep. those things.
and PLEASE. always use the tie down straps. BAD things happen when your lazy ;)
I loaded my first bike with a 10ft 2x6! cracked it on the way up, got home and unloaded it with an 8ft 4x10 slab of milled juniper! where there's a will, there's a way.
I picked up one of these with some birthday $. It's 500 lb max capacity. I'm thinking about returning it for a 750 or 1000 lb. capacity, just in case. My bike was 460 lbs stock. I removed a bunch of weight (fenders, stock mufflers, big gauges, airboxes, electric starter bits, gear, and chain, big battery & battery breather box), but I'm a bit weary of pushing my luck with the ramp.
http://www.tractorsupply.com/vehicle-ramps/better-built-arched-folding-aluminum-loading-ramp-1000118
Two old metal angle iron bed rails with some flat stock steel welded between em to form a channel of sorts. Rig up an anchor point, bobs your uncle. A bit heavier than alloy but hey, are you gonna cart it round full time?
before i got a ramp i would take the truck and the bike to a local grocery store, in back is the loading doc, back the truck up to that and just ride it right in.... also a great trick to get your bike out by yourself!
Most ramps you can buy are for dirtbikes/ATV so are too short.
I'm thinking of making a fold up ramp from angle as even the longest one is too steep and exhaust catches on lip/tailgate.
Need about another foot or so to lessen angle.
F150 has higher bed than my Mazda B2300.
PJ
