twistekeys
By the way, Sonreir, your avatar matches your post style perfectly.
danejurrous said:I think what he was referring to was the fact that a super charger will take some horsepower to make some horse power for an example: takes .5 for every 2 it creates. (Not real specs just an example) Where a turbo charger does not rob horsepower from an engine to create horsepower is just uses the exhaust gases rather than a manual link with a pulley or gear where power is lost.
The feasibility of putting one on a bike is not really something I would delve into because if you have the determination to do it you can make anything work. That being said I would probably put my time and money into other areas than a turbo.
twistekeys said:Also what configuration gives that blowoff sound? I want that.
twistekeys said:That sounds RELATIVELY easy compared to charging. So why can't you achieve a higher amount of fuel with a wider jet setup in-carb?
stevenfrye said:On the bike Im slowly but surly putting together, i modified the gas cap to seal with a 11 pound spring, and a line (with a one way check valve) fron the airbox surrounding the carbs pressurizing the fuel tank. to keep from going to a rich fuel situation i have a bleed off into a small carbon can with another check valve and line to the vacume manafold.
stevenfrye said:Basically what I was trying to say instead of using another fuel pump I'm going to see if I can put pressure on the fuel by way of the boost the turbo is producing and the carbon can set up is going to be used as a vapor catch can and tank pressure release so I don't dump too much fuel into the carbs going from high throttle / high boost to low throttle and the excess pressure bleeds off into the can. I'm working with a kz 550 motor, and just figured out today digging around the motor on the exhaust valves are sets of reed valves that receives fresh air from the intake via case breather and forces air into valve reducing backfiring apparently according to the manual and just so happens to be the perfect place to plumb the compressor blow off too.
stroker crazy said:Anything else is just an excuse to show off your engineering skill (or lack of)!
Crazy
