Turning Over a CB550
sxecafe
You think the Carpet Pissers did this?
Hey Dudes,
Im getting ready to start work on my 74 Cb550. When I bought it, I turned the the crank over with a box wrench to make sure it wasn't seized but there was no stator on it. I want to make sure there is sufficient compression before I start anything else on the build b/c if there isn't then I obviously have to add that to the list of things to do.
I purchased a stator which is now on and from what I am told, I basically have to jump the motor with a battery and then see there is compression. I tried this earlier this month but I am clearly missing a piece of the puzzle here as it wont jump... Has anyone done this and if so, could you outline the steps and what I have to have connected? I dont want to start the engine so I have no fuel hooked up. Just plugs, battery and stator...
Thanks!
We're currently working on a buddies 1975 CB550 that he picked up from a buddy. It'd been sitting outside for at least 5 yrs and was froze up solid. We wound up having to cut the master link on the cam chain to remove the cam shafts so we could get the head and jugs off to free the pistsons. We haven't been able to get the starter working yet so we just used the kick starter to get a basic compression test. Does yours have a kick start on it?
To be honest... I dont recall but thats a much better option! Ill check tonight. Thanks for the insight.
How did yours turn out?
The starter clutch is buried in middle of engine, you dont need a stator on it to spin it over.
Just connect one jumper lead to a good ground on crankcase (negatine terminal) and other jumper lead to starter terminal (under chrome cover , top left behind cylinder)
PJ
Remove the plugs(sparking type)insert a compression tester to one cylinder(one at a time),,,,,,,start pushing in third gear,,,,,,,,,,,or kick it over,,or jump the starter with booster cables. you need to record compression of each cylinder,,
