two stroke exhaust HELP!
dwmarlin4114
Active Member
Hey guys i've been doing some research on 2 stroke exhausts and I think I understand a good deal of it but still have some questions. The expansion chamber in the header is the shape and size that it is for a reason pressure and wave return to help draw exhaust / intake gases. Thats all fine because i have no desire to mess with any of that however the stinger section (the part after the convergent header cone back to the silencer I want to change.) The research i've done tells me that the stinger section helps reduce internal temperatures (more length = more ambient air contact = lower temperatures right?) if the silencer is unchanged will I have backpressure issues if the stinger is shortened or just a higher pipe temperature? PLEASE HELP.
Here are some pics
STINGER
STINGER SHORTENED (obviously photoshopped)
Is this a possible mod? Has anyone done anything like this?
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&sqi=2&ved=0CGcQFjAA&url=http%3A%2F%2Fwww.vintagesleds.com%2Flibrary%2Fmanuals%2Fmisc%2FTwo-stroke%2520Tuner%2527s%2520Handbook.pdf&ei=-I7WT8rqJI_nmAW61omhAw&usg=AFQjCNH5g3pT_MrvXuaGhXcDnb-GhSW2mQ
Gordon Jennings Two Stroke Tuner's Handbook .
He doesn't stray far from the truth and the only caveat I can give is that there have been recent advances in two stroke "exhaust valve" technology since it's publication that affect many things . Even a brief search of the forum will find it referenced many times . In short do not shorten the stinger w/o first reading the handbook .
~kop
From AG Bell's 'Performance Tuning in Theory and Practice':
".... the stinger, is in reality a bleed pipe. Its function is to restrict gas flow out of the exhaust and create back pressure by slowly bleeding off exhaust gas. This serves to assist the positive pulse in pushing any spilled fuel/air charge back into the motor." (pp.81)
"A stinger pipe smaller in diameter or longer than specified could easily result in engine overheating and seizure." (pp.82)
Expansion chambers are probably the most critical component of a two-stroke design and about the most difficult to get right. Manufacturers spend a lot of time and experience on chamber design and it is almost impossible to alter just one section without bringing about negative effects. Shortening the stinger could make the motor run cooler, cause a drop in horsepower, and dump unburnt fuel into the chambers with a resultant negative effect on consumption figures.
In short, while a complete redesign might help a stroker's performance a chop job is likely to be disappointing at best.
Crazy
Various chamber design programs have their uses but still need input from someone with practical experience in the real world.
As the heyday of the two-stroke fades into the past, finding an experienced designer and/or fabricator becomes increasingly difficult.
Most have retired or been visited by the Grim Reaper!
Crazy
Crazy
that reminds me teazer stay healthy and take your vidamins im gonna need your help
