TX500 Bobber Build
bobber
Hello guys and gals if any. I have a little project im working on. A n1973 TX500 bobber. I woant to change my speedo and tach to mini guages and i'm not sure what ratio speedo i need. i have a 19" front tire. As for the tach, it is a mechanical job and i need to know if there is a certain ratio to use for that. Any help in these areas would be greatly appreciated. ???
First of all, welcome to the site!
There are only 3 ratio's for speedos that I know of - 1:1, 2:1, and to my knowledge all metric bikes use the 2240:60. Check out www.MikesXS.com for great deals on the minis.
The tach on the other hand is beyond my knowledge. There's a thread in here somewhere that mentions the tach ratios, I believe Wee Todd had the answer for it.
Good luck!
Thanks Big R for the welcome. Everything that I have found about the 2240:60 ratio says its for a 21" wheel. My front wheel is 19" ?I actually sent an email to MikeXS and he said he has no knowledge of my model. oh well the search continues.
To JRK, what ratio did you buy from cyclexchange? i only see honda items.
i wish i knew, i am pretty sure they only sell one, sucks i do not know bud i got it in a ebay auction.
Probably the easiest thing to do is check out some digital instruments - a lot of them (if not all) are programmed using a measured mile. So it wouldn't matter what size tires you have.
Same goes for the tach - just match it up to your coils for the rpm's
