Upper Fork Covers
Drewscottband
What are you guys using to cover upper forks on a CL350 '71? I got rid of the upper covers w headlight ears because I'm mounting a front fairing. Looking to make upper forks look good. 33mm
Thanks for the help!
Looks nice. Won't your fairing cover the upper fork tubes? Not sure there's anything else you could do except make some new covers or cut out slots in your old one for the new headlight/fairing mounts. I don't mind ithem being exposed on my CL350, although the fork tubes are a bit spindly looking.
Fairing won't cover them up how I'd like. I think they look spindly as well.
That's because they are spindly.
You need a fork brace or they twist like pretzels.
Many people fit 35mm forks from larger Honda's as that's easiest thing to do.
USD forks from late models look way too big being 50mm+ which makes everything else look skinny plus fitting stock wheels becomes way more difficult
If you decide to go with 35mm forks you can use the trees from a 74 or later CB/CL450 or 500 Twin or from the CB500/550 four. They bolt on and the steering stops work with your frame. Same for the forks from the above bikes plus the 73-79 CB750 SOHC. There are other donors but these model Honda forks work very well on a 350/360.
Good to know! Thanks man
