Upping rear shock lengths?
chilli
Learning, swearing, breaking, fixing, making.
I'm working on a Yam sr20 project. Thinking of replacing the rear shockers as they are pretty flat. the stack length is 300mm and I'm looking at options of 325mmm, 365mm.
Any ideas on how much I can raise the arse of the bike without seriously messing with the handling? Bearing in mind it's an SR 250.. I'm also thinking of dropping the front forks an inch or two through the tree.
you're decreasing the ground trail of the front, and shifting the weight distribution forward, so with most older bikes, that will be an improvement, but the stability decreases, make sure your steering bearings are good, the stiction in your forks will increase as well, so those may want to be upgraded... steering damper wouldn't be a bad idea either
Hmm thanks. This is a first project on a tight budget (and the mechanical knowledge of a gnat!) so I don't really want to solve one issue and create four!
Maybe better to compromise on newer shocks with just 25mm extra length which I'm guessing won't overstress the front end?
Another thing to consider is the chain line - it may rub on the top of the swingarm if you go too high on the new shocks.
The SR is pretty "cruiserish" in it's geometry, so the longer shocks should only help the handling (as long as the chain line is OK)
