video 71 450 first start.
beard
pro blowhard
$100 71 450 CL
tinkered with it at the end of the summer and put it away in the fall with the thought.. all she needs is gas
well added gas and she ran.(dont mind my gas tank on the handle bars or my lack of battery)
idled for over 1hr or so.. got it real hot burning off all the dust and what not..
started to get a small leak at the shifter post.. seems to be alot of in and out play there.
idle was fine.. but if u rev'd it.. it had a tendecy to want to stay at high rpm.
http://beard.freaksho.net/data/etc/car/450.wmv
i have a 71 350cl too. hoping i can pick the better motor and peice together from there.
$100? :o Lucky bastard. The video is blocked here at work, but I'll check it out at home.
I had a similar problem with my shifter. It eventually got stuck in 5th. Turned out a circlip had popped out of a groove under the front sprocket cover that keeps it from sliding too far right. Make sure that, and the large washer are still there. There is probably some kind of seal behind that washer that may be leaking.
I think syncing the carbs will get it set settle back to idle better.
Hope you had a fan blowing on it... Those air cooled engines don't like idling for long periods of time.
