ways of making gaskets from gasket paper
I'm usually only making a gasket when I can't wait to order one.
Last week I pulled a Virago side cover to deal with the dreaded starter issue for a friend, gasket tore and was jacked anyway. Needed a gasket that night to get his bike back and didn't want to wait for a gasket. Took me about 30 minutes to make one..
Its good to have the parts and materials onhand. I wouldn't suggest it for a full rebuild, but, if you don't have the cash you don't have the cash and you'll be a better person mechanic for it.
yeah last gasket i made was the hard to find stator side case sl350 gasket
i would much rather just buy them all,every time
After making one yeah I'd rather buy them, but if it's $40 for gaskets or a cool fender or etc then I'd rather spend $5 on gasket paper and another hour making one
I have more time than money ( I'm retired ) so I generally make my own gaskets ..
I lay gasket paper over the part and use a rubber mallet to " imprint " the shape onto the paper. I don't like beating on alloy and aluminum parts with a hammer... just sayin . It's fine on cast iron parts.. (My dad used to "hammer out" gaskets from cereal boxes etc ... whatever was laying around...... )
Then I use a x-acto knife and hole punch ... gaskets look much nicer too because the edges are generally visible when installing case covers etc...
great video! and do you think you could use that hammer method but instead of using a metal hammer, use a rubber one? or would that rubber not cut it?
Refer to DeanJ, 2 posts above:
When taking all my covers off to polish i just traced all the old gaskets onto gasket paper and cut them out with a new box cutter and exacto knife. I also used a small hole puncher. Also check out gasketking.com when there site is back up and there is another thread on here or sohc where the op can make you any gaskets you want. I'll have to find that for you.
Sent from my SCH-I535 using Tapatalk 2
When I polished all the covers of my cb750k2 I scanned all the covers and made an adobe illustrator tracing of them, the laser cut gasket paper. Works pretty well.
You could use a plastic hammer to make gasket via the hammer method. its not so much the hammer doing the cutting, as it is the piece you are making the gasket for.
You shouldn't break said aluminum part with a metal hammer anyway...its not like you are hitting it with a ton of force, just enough to cut through gasket paper...
