Weak Spark !!! Need Help
lovell
Hi there, I have just about finished a rebuild on a 1970 CB 175 that I purchased after sitting in a shed for the past 10 years.
The problem that I have now is that the bike has a VERY weak spark, which seems to cause the plugs to fowl after only a few minutes of running.
I have a new battery, points, coil and condensor. The point and plug gaps have been checked, re-checked and then checked again. I have also tried 4 different sets of new plugs.
I have also tried the old coil, and another new one.
To eliminate the timing as an issue or even the plugs, I am checking the spark from the plug lead earthed against the motor and it remains consistently very weak.
I have also wired in a new blade type fuse and pulled out the stator to check for any broken wire but to no avail.
I compared the spark from my neighbours bike (hotfunk67) and they are SOOOO very different.
Does anyone have any suggestions as to what else I can check, or can tell me how to test if the stator is producing enough power ?
Any help would be greatly appreciated cause I can't wait to ride this thing, but for now she's not going anywhere.
