Weird (high) idle speed
andrew embassy
So, my idle speed is really high - except, if when I'm in neutral, I'll let out the clutch and it'll come down to a more normal RPM - which order should I troubleshoot this? I'm assuming it could be something with the throttle cable, or maybe with my fuel mixture?
Also, man - seriously I need more space in my garage. It is CRAMPED with all my crap in there. Anybody want to buy a ton of junk?
pulling the clutch in and out shouldn't affect the idle speed. It sound like the clutch cable is somehow interfering with the throttle cable.
well, now it's kind of turned into a constant 5K rpm whenever it's not in gear - I gotta do some adjusting somewhere...
i dont know bout u, shouldnt be the same problem i had.
but there was this one time, i had a high idle speed, even when i wasnt revving. turned out my throttle cable was about to snap.
just food for thought.
yeah, it could be so many things. Leaky intake manifold causing it to lean out. float improperly set (although I'm not sure it would bring it up to 5k). One problem I had was that the springs on the mechanical advance mechanism were stretched out. It would sit at idle for a second then rev itself up to 3k. I pulled the mechanism and tightened up the springs. Took a bit of tweaking to get it to advance at the right spot.
It may be a bit drastic, but try disconnecting the throttle cables and see if it still does it. It should idle even without the cables.
Have you gone through the process of syncing the carbs yet? Mine was a different beast (much better) after I did that.
You're exactly right. I wiggled stuff around and we're better than when I got it from the dude. Perfect! I had this terrible feeling that I had somehow had the choke on or something...
That means I can ride it around tonight!
