m511y
Less is more
I removed the bearings from my front wheel off of my 79XS750 and one of the sealed bearings was only sealed on one side. At first I thought I lost the seal, but it is meant to be that way. Why? Wouldn't it be better for a bearing to be sealed on both sides even if it is inside the hub?
The real reason I'm asking is because I'm attempting to swap the 19" XS750 front wheel with a smaller 18" XS400 front wheel and the only bearings I can find that will work are only sealed on one side. I want to be sure I don't use bearings that could seize at some point because they weren’t sealed on both sides.
