dartyD
Active Member
So everything on the bike was working. I have a 1971 CL350, But i had to get a court order title for it so i just left it in the garage for a while. Then i decided to tinker with it. My battery is dead so i use my truck to jump it. (Ive also been told thats not good to do) but when i hooked the jumper cables up and made sure i had a good connection nothing at all came on. My fuse looked fine so idk what else it could be besides a loose ground. Do i use a volt meter? And if so, how/where do i use it. And totally of subject, my clutch is soft. What are the chances that i could adjust it rather than replace it? Ive messing with the clutch adjuster near the shifter but im having no luck.
Thanks, Seth
Thanks, Seth
