Wiring "Issues" = I'm dumb, please help
rabq08
1976 CB750K
Ok, so Ive just finished installing clubman handlebars and have begun trying to rewire the rats nest behind the headlight. I though it would be no bid deal as all the wires are color coded, i was so wrong. I have wires that don't match up to anything. I wired the bike as much as made sense and the bike does nothing, no power to anything whatsoever. I have looked over the wiring diagram in my Clymer and it is no help. If you have any advise or pictures to help me out of my jam please post them. Close up pictures of the wire connections inside the headlight bucket would be kick ass. Thank guys.
Thanks for that pj.
UPDATE: The 5A fuse was blown so i replaced it. When i hit the starter button it blew again, somthing is miss wired and i can't figure it out.
rabq08 said:
Thanks for that pj.
5A fuse sounds small for that bike, should be 15A. If it's blowing when you hit the starter, start there, check the solenoid and maybe try bypassing it to see if it still blows, if that's not it move to the coils..and just keep by-passing components until it stops blowing.
rabq08 said:
Thanks for that pj.
5A fuse sounds small for that bike, should be 15A I think. If it's blowing when you hit the starter check the solenoid and maybe try by-passing it. if it still blows check your coils maybe by-pass them too..it's a bitch to figure these things out but persistent process of elimination will get you there.
Thanks for the advice herm, it is a bitch. I'll keep plugging away, in the mean time i think im going to draw up a diagram of all the wires within the headlight bucket in MS Word, make all the connection i can, then post it. Hopefully somebody more wise than me can help "connect the dots."
follow the wire from the starter button as well.... when movin wiring around some get kinked or worn. could be causing a short
you know.... you're not going to like this, buuut.... whenever I have a wiring issue as buggered as that, I just yank all the wires apart in the headlight, and get them all out of there, then look over the wiring diagram and start from scratch. works every time for me, there's always that one shadetree mechanic in the bike's history that screwed around with the wiring and "got it working" but the turn signals will only work with the clutch pulled in etc. etc. etc., so screw the whole thing and start from Mr. Honda's idea of what goes where
I agree +1
OkOkOk :P, i guess that's the next course of action. Thanks all for the input, ill update after i get some work done this weekend.
