XJ1100 help!
mark13018
"In the age of information, ignorance is a choice
Hey guys, I know this isn't the xj forum but I know there are some xj owners on here...
So I have that xj1100 for sale and the tach isn't working properly and a guy stopped to look at it and said it probably wasn't firing on the second cylinder so I took the plug out and turned it over and it fires on the second cylinder and while I had the spark plug against the head the pressure blew out air and this connector fell down which probably operates the tach. It is firing on all cylinders but the tach is still not working and I can't find where this connector goes on the bike to hook it back up. If someone is familiar with this bike and knows where this connector goes. Maybe even with a picture of theirs that would be amazing!! Thanks for your help!
From things I've been reading the xj11 and xs11 actually have a lot of differences than most people think... the oil light/sensors are different also... all that aside though. This connector shown is what I'm trying figure out where the other end is on the harness... can't seem to find it anywhere. It may be for the charging system or just the tach... I haven't tested the charging system yet but it hasn't killed the battery yet either... if you have this connector on your xs11 and/or know where it goes I would greatly appreciate the help! ;D. Thank you!
Do you happen to know where the other end of that pig tail comes out if the harness?
