Pretty much everything you need to do the Brembo swap. Brembo caliper, master cylinder and Pandemonium Choppers bracket. I believe this particular bracket it for the 34mm forks. Somebody correct me if I'm wrong, but the bracket will work on the 35mm forks but you'll also need a spacer to fit behind the rotor.
$175 shipped for everything.
