The throw -out mechanism is the mechanism the clutch cable attaches to under the left side cover. If you replaced the clutch, or any components in the clutch, the stacked assembly of parts can be thicker than before. This would require adjusting the throw-out mechanism closer to the push rod to compensate for the extra thickness. That is the whole purpose of the adjustment - to move the whole throw-out mechanism into the right place so it can accommodate variances in the stacked clutch parts, as well as tolerances in the cases.
Different oils and different friction plate manufacturers can have a pretty big effect on clutches, so if the adjustment is ok, try some different oil. I have used Shell Rotela non-synthetic with good results in similar situations. It may be called something else in Sweden - it is Shell's commercial diesel oil.
