Well. . . seems a bit disturbing! US models look to be the same regarding the neutral switch. See pic below for reference. Have to go to some pretty basic things first. Have to know that the transmission absolutely is working correctly. This can be done by spinning the input shaft by hand. Shift the trans through all the gears and verify that each gear speeds up the output shaft compared to the previous one. Go back to 1st, and then place in neutral. Since you still have the cases apart, you can look at the detent cam (the star shaped plate fixed to the shift cam/drum with the big snap ring. It is on the right side of the engine, attached to the end of the cam where the neutral switch contact is) and see that the "short" notch between two of the high lobes is aligned with the spring loaded plunger that screws in from the bottom of the lower case half. That detent cam can only assemble one way, and is symmetric so it can not be installed "backward". If it aligns with the plunger, it is in neutral and the contact has to align with the switch cover. All of that can be assembled with no transmission shafts, and no gear selector components. Since you still have it all apart, maybe start again with the lower case half bare, install the shift cam/drum, install the detent plunger assembly, and verify the switch contact is at 3 o-clock when in neutral. I may be confused by your pics if they are not current, take the clutch out and spin the trans by hand to test if it is all together.
I don't believe it is possible to assemble the trans incorrectly and not have a very obvious problem, but then again I have never tried to see if it was possible, so I am actually making an assumption. If you verify with certainty that the trans does indeed work properly and when in neutral that contact does not align with the switch cover, I can only think there is some incorrect part in the assembly? Seems wildly unlikely. Let us know that the run through the gears works properly.
Keep in mind that it is very possible to have a false neutral between other gears, so just because you can spin the output shaft without spinning the engine is not proof you are in the "real" neutral.
