your expertise needed!
stpilotdesmond
Active Member
So I have a 75 Honda CB360 which I bought new turn signals for. The rear turn signals shouldn't be much trouble to install since they come with two wire and the stock signals had two wires also. The stock front signals, however, are a different story. They have three wires and the new ones only have two. The extra wire is power for the running or position lights.
I'm pretty sure I've figured it out. I don't want running lights so just forget about that wire. It's just a matter of figuring out where to connect the wires into the stock wiring harness. I need your help to tell me if my thinking is correct or if I'm a re-tard. Here's what I'm thinking:
On the new signals the black wire is the ground so I will connect the black wires into the spot where the green wires from the stock signals connected. (see wiring diagram below) So that should take care of the ground. Now, if you look at the bottom left of the wiring diagram you will see the turn signal switch and there is a R and L, obviously for Right Signal and Left Signal. Let's follow the R... it is a LB wire that connects to another LB wire that goes to the front and rear Right Signals. So, all I should have to do is connect the one remaining wire from the new turn signal into the LB connector, right?
I'd do the same for the other side. Is my thinking correct with this?
Yep. Ground to ground, LB is your positive signal wire.
What colors are the wires on the new signals?
Colors on the new wires are black and black/white. I got them from Dime City Cycles and they told me black is the ground.
Yep.
Light Blue for one side, Orange for the other.
Black - Green
Black/White - Orange or Light blue.
Easy Peasy.
Spent the morning hooking up the new turn signals and taillight. I did the turn signals first and they worked perfectly.
Then I hooked up the stock rear brake light to see if it worked to make sure all the wiring was okay. When I turned the ignition on the brake light lit up for about 3 seconds and then blew the main fuse!!! ARRRGH. Why would it do that? This is my worst fear. I'm so close to having the bike done and now I have an electrical problem. This could take forever to solve... I'm resisting the urge to throw the bike in the dumpster.
Any thoughts or suggestions? Any help is appreciated... I don't even know where to start.
Figured it out! When I was in the headlight hooking the turn signals up I discovered a disconnected wire which belonged to the front break switch.
I thought, "Well that explains why the brake light doesn't work when I squeeze the front brake. I'll just hook it back up and it'll be all set."
So, I went out to the bike, installed a new fuse and turned the bike on without the taillight connected and it still blew the fuse, so I knew it wasn't the taillight. Then I disconnected the front brake light switch and installed another fuse, turned the bike on and the fuse was fine. Hooked up the new taillight and everything works.
Now I'm just waiting for a fiberglass seat from Dime City to arrive ;D
