I bought a 72 DT2 to get around on until I have a bit more $ to either rebuild the 600 motor or find a parts bike in good shape. Haven't made a thread about it, cuz there wouldn't be much to say at this point. Figured I'd ask here instead of starting a different thread that wasn't gonna go anywhere.DohcBikes said:wtf bike are we talking about and where is the thread
DohcBikes said:or just use engine oil
learn to swim
That is what I assumed. He could just be turning the end of the crank with a wrench for all I know. I'm not attached to this motor or anything, it just came up and thought it might be worth checking out.hillsy said:Caveat emptor....
How does this motor "turn over" ?? Has he hooked a battery up to it and is cranking it? If so, you could take a compression gauge and check that out, but it's still a lucky dip.....
CALfeRacer said:I also noticed some grooves from the friction plate tabs on the clutch basket outer, not sure if that's a problem.
I didn't want to take too much material off them. I guess I could file them and see what thickness they end up at. Some of the pits are pretty bad, already tried hitting it with some sandpaper and steel woolhillsy said:Happens all the time - just file them down.
