stidds said:Man that is so beautiful, if my CB turns out 1/2 as good as that I will be stoked.
Your bike also looks so pretty lounging in the sunshine.
Cheers Ringo yeah we are blessed with some keen weather!!! I hope your staying warm in montana brother!!!Ringo said:Looks great, Stript! And I'm envious of that prefect riding weather! Socal sheesh...
Thanks Louie. i saw you in a OC post you live hear ?Swapmeet Louie said:I'm digging this build. I like the absolute minimum approach, surrounded by obvious attention to detail. Really clean machine ...
I love it!!!CrescentSon said:Congrats man. A one of a kind experience for sure!
Nice. not to rub it in butt it was 80 out in CA today ;DSpottheDogg said:I wish I could go for a ride, the snow is 4' deep in my yard :-\
Give me a few more weeks and I'll take the VFR out.
stript.714 o/c said:I ran in to some minor issues today. when i was riding my clutch sounded like it popped, and then my clutch cable all of a sodden got an abundance amount of slack. Was my cable adjusted to tight maybe?Also my idle is way high i know i need rejetting. If i run my bike this way can it cause it harm?I did a warm compression test and i only got 125 psi from each cylinder. i know i want around 180 psi. I never hoaned my cylinder jugs. i only putt new rings in. If i hoan will it bring my compression up?
MY bike was running fine butt on my way home its like i got a loss in power i was giving my bike gas and its as if i wasent really going anywhere . Any suggestions? . I think it is a carburated issue !
Yes it was reving up and not really responding . I had just re adjusted the clutch do to being stranded . Did i adjust it wrong or do you think i have an issue with my clutch plates, or springs?AimSmall said:Was it revving up but not accelerating? It sounds like your clutch is slipping. Just start bumping the jets one size at a time (main and pilot), the popping could just be a lean pilot jet, the high idle makes me think the carbs aren't completely clean too.
I really like that seat, where'd you get it?
