Well boys and girls USPS finally got their heads out of their...you know.
The replacement bearing arrived!
I plopped the race immediately into the dry ice I bought for this occasion a couple days ago. Thankfully enough survived.
After some smacking with a punch, she was seated! I lubed the bearings and installed the lower triple! Progress!
With the assistance of my roommate I was able to slide the forks into the trees without flipping the bike off the center stand.
Then it was a simple matter of sorting out the clipons and doing some temporary wiring for the controls (which will be readdressed at a later date when the entire harness gets a makeover). Slap the wheel on and we're good to go.
After wiring the ignition, starter and brake lights I slapped the tank and seat back on and took her for a shakedown.
Nothing fell off! And holy crap the brakes were 10,000 times better. I can lock the front tire with two fingers now, I couldn't do that with two hands on the original setup. Also my low speed turning radius is severely decreased. As I Austin Powers'd my way out of my driveway I saw in a new light the draw of tank dents on bikes with clipons.
Tomorrow will be a lot more wiring and a couple more test runs to see if I remembered to tighten all the important bits.
As a note, is there a quick and easy way to shorten the kickstand? On the old setup she barely leaned, and with the lowered front the side stand is basically useless. I meant to take a look at it tonight but it's still 82 degrees out and I sought the AC instead.
