I've seen the threaded tappet hole oval out. You could thread it in tight, even get the locknut on. Then, when the engine ran, the tappet shifted back and forth in the oval and it would slowly loosen up.
deviant said:I've seen the threaded tappet hole oval out. You could thread it in tight, even get the locknut on. Then, when the engine ran, the tappet shifted back and forth in the oval and it would slowly loosen up.
Tune-A-Fish said:Like i said get one more good adjustment and weld it, then next time if the followers are sweet, have a set of Britt mushroom heads and tap ready to cut in some new threads... Those Britt tappers are just slightly larger
xb33bsa said:i only mentioned the egged out rocker tip threrads because i lhave seen that issue on these boards at least once it was discussed ,if the cam and follower were in that sad a shape ,to be knashing wearing knurling and galling,and continually loosening then i would think the oil would shine like a bass boat under the bug light in a 7-11 parking lot
all sparkly like just sayin'
.so op is your oil all metal flaky ?even a little or not at all ? you may need to drain it to look close and bust open the filter , see if it serves as witness ,and check them female rocker tip threads,,,,....,,,,,..//.'
motogp, the penultyimate round,sepang, up next
barnett468 said:nice.
Tune-A-Fish said:Adapt and overcome, ride or watch yer buds ride away...
barnett468 said:yup, however, if my bike is broken and my buddies ride without me, it gives me time to go hit up their ol' ladys....or daughters....or BOTH!
barnett468 said:Holy crap....Barns bike is broke...better lock the doors and hide the dogs and chickens!
Tune-A-Fish said:But we all know he likes the pee nut buttr boys better...
Tune-A-Fish said:A regular at the rocky horror show eh? ;D ;D
MR915 said:Once again....I disagree based on my experience with air cooled motorcycles.
