We're going to throw some of our bolt on kits in on this as well.
CB350T- $225 + the ride.
CB350F- $200 + the ride
CB360- $225 + the ride
CB450- $225 + the ride
CB500- $200 + the ride
CB550- $200 + the ride
CB750 SOHC- $200 + the ride
XS650- $250 + the ride.
All come with linkage with heim joints, SS bolts for lacing everything up, and the pieces for the shift and brake shaft. They are a full bolt on kit.
The CB350T, CB360, and CB450 come with a specialty pivot we have designed for each of the three that allows you to run a linkage rod forward to the pivot that utilizes the stock brake rod, light switch, and return spring, rather than running a bent linkage rod directly from the controls to the drum. It is far more efficient.
The XS650 set is the only set we have seen on the market that allows you to use the kickstart.
Same as the universals, folding pegs $20 per side additional.
XS set comes with folding on the brake side to clear kicker.
