I've made a list of all the possible reasons it won't
start idle, based on what is in the Clymer:
Definitely good. Checked with new plugs.
Fuel is getting to carbs. Couple turns on drain screws and fuel comes out, and I can see it flowing through the filters.
Need to get a Comp Tester for this.
Noticed it leaking oil out the side of motor since its been running.
Every now and then the rail gets a little snagged, but poking it gets it to operate just fine.
Probably off on adjustment, but worked fine on the shakedown the other day. Re-routed correctly but the broken mount on the carb makes it a bit loose.
Floats are all good and float height is within range.
Pilots set to 2.5, will vac check but carbs were bench synced.
Filter appears fine and bike runs with it in place.
I already set valve timing and gap a couple months ago to factory specs.
I'll try to go through all of this tomorrow in order from easiest to hardest, don't wanna pull the carbs if all it was is a bad filter.
