Honda CB350 Running on 1. Has spark, compression and fuel
but yeah it is a process of elimination sometimes simply having the wire connected incorectly at the points,it needs to be isolated from ground,this alone has caused many to frustrate
xb33bsa said:
he says in the first post that they are spotless and clean
Not sure if we're reading the same post -- he says in the third post he replaced them a month ago. Oil or dirt can foul points if they are a day old or two years old, doesn't hurt to check. I'm not saying that's definitely it -- weak battery is a frequent culprit on these with these symptoms, as others have pointed out, and a bad condenser, or grounding issue or... everything else that people have suggested.
so i started today attempting to do what was recommended besides swapping out the condensers and coils and when i turned it on the points which i just had hooked up were smoking for a half second before the fuse blew i am hoping that someone has had this problem before? i need to wait until i get a new fuse before moving on. hopefully the old fuse was just old and the points were burning off the imaginary oil on them.
here is a crappy video of my wiring harness.
https://www.youtube.com/watch?v=qWytNTc8TSA&feature=youtu.be
so speaking of my wiring harness anyone ever had anydealings with agatha_cycleshop on Ebay, for the pair of remanafactured coils? these ones?
http://www.ebay.com/itm/251864329007?item=251864329007&viewitem=&vxp=mtr
I have heard of several people using Yamaha XT600 coils on their 350s and 360s.
http://www.amazon.com/IGNITION-YAMAHA-XT-600-XT600E-MOTORCYCLE/dp/B00IWRH4X4/ref=sr_1_1?ie=UTF8&qid=1428967972&sr=8-1&keywords=yamaha+xt600+coil
I've installed Yamaha XS650 coils on my CB350 and the only mods I did to the bike was mounting them differently under the tank but they work fine.
so your sure i can get the
http://www.amazon.com/IGNITION-YAMAHA-XT-600-XT600E-MOTORCYCLE/dp/B00IWRH4X4/ref=sr_1_1?ie=UTF8&qid=1428967972&sr=8-1&keywords=yamaha%20xt600%20coil&tag=viglink22046-20
for my bike and i won't have to modify much or get extra parts? I am a broke college student so not much extra cash if any.
Here's a write up from another member.
http://www.dotheton.com/forum/index.php?topic=52309.msg584572#msg584572
so now i feel stupid found the problem when i removed the points and moved the blue wire around a little it broke off just inside of the case. (I have moved it around before just saying so not the first time i have touched it.)
so here i am again with another problem.... My points are turning on at around 150-180 degrees off the LF mark and the F mark. I am assuming i did something very wrong and stupid. Please any help with pictures would be great or no pictures either way.
