two-smoker said:The TX has oval shaped intake ports, so I'm pretty sure it's best to stick with the stock boots. Initially I used some scrap nylon sheet from work as a shim around the carbs, now I'm using strips of inner tube sealed together with rubber cement to prevent air leaks. Might be worth a shot.
DreadRock said:am working on my VM32s now and found that the hose clamps needed replaced with better ones then the boots came with To seal right Running stock 500 boots on them ;D
AzHonda said:So do they work fine with replacing the clamps or did you have to do anything else to the boots?
DreadRock said:Out standing sir came out nice
On the wiring behind the headlight could mount a small black box behind and between fork tube to hold the wiring ? Not sure which HD runs them think FatBoys have a cover plate over top of the trees. Something like that black could work too ?
trek97 said:Thats it...her name...
MEAN GREEN LIMA BEAN
Im just teasin bud. I love it.
