Innamorata 750
Active Member
I took some time off from my KZ750T project to get a new daily driver together.
I started with my 1989 Jeep Grand Wagoneer. It currently has its stock 360 and 727 transmission, backed by the NP229 transfer case.
Exhibit A:
It's pretty much rust-free, with a few hail induced dings and a rather tweaked hood (it came open at some 35mph :shock: )
My plans (comments welcome!)
Drivetrain
-LY5 5.3 (from a 2008 Silverado)
-4L60E (2008 Silverado)
-NP229
Interior
-Thunderbird Turbo Coupe front seats
-Custom console
-Custom dash
-A/C from a 70's Chevy truck
Body
-Wide Trac flares
-Maroon paint
-Custom woodgrain
-Suburban 42 gallon tank
-Raised rear floor (2"-3") to accommodate tank.
Wheels/Tires/Suspension
-31" or 32" tires?
-15" wheels? 17"? 18"?
-Stock height? 2" lift?
I made a parts list:
LY5/4L60E.............................................Ordered...........2008 Chevy Silverado
Modify Harness.......................................TBD................Wayne Hartwig/Diff Wizard (suggestions?)
Engine Mounts.......................................Received..........JeepinPete
Transmission Mounts...............................Received...........Ebay Vendor
Transmission Rebuild Kit..........................Received...........Transtech
Transmission/Transfer Case Adapter..........Received...........Novak/BJ's
Transfer Case Seal Kit.............................Received..........Ebay Vendor
Radiator................................................Received..........Griffin '67-'69 Camaro LS Swap (Summit)
Radiator Fan..........................................Received..........Lincoln Mark VIII (Ebay Vendor)
Radiator Hoses......................................TBD
Fuel Tank..............................................Received..........'98 Chevy Suburban-42 Gallon (Ebay Vendor)
Fuel Pump/Sending Unit..........................Received..........'98 Chevy Suburban (Ebay Vendor)
Fuel Lines.............................................TBD.................PTFE Lined Braided Line
Fuel Filter/Regulator(?)...........................TBD
Shifter Linkage......................................Ordered............FSJ Turbo 400 (ScottsMojo)
A/C-Heat Unit........................................Received..........'70s Chevy Truck (Integrated Heat-A/C)
A/C Evaporator......................................Ordered............'79 Firebird
Heater Core..........................................Ordered............'70s Chevy Truck
A/C Condenser......................................Ordered............Polar Bear Inc
Transmission Oil Cooler...........................TBD
Transmission Cooler Lines.......................TBD
Power Steering Lines/Adapters................TBD
Driveshafts...........................................TBD
Gauges................................................Ordered............Speedhut
Transmission Rebuild Tools.....................Received............Ebay Vendor
Wheels................................................Ordered.............Jeg's (Ultra Wheel Type 50/51)
The engine arrives!
Out with the old... (oh, it's for sale too!)
Air Conditioning mock up...
Behind the dash...
In with the new...
Clears the firewall nicely!
Notes: The JeepinPete mounts were PERFECT! I mounted the engine 1" forward of the original forward holes. By doing this, the transfer case is within an inch of its original mounting, and thus the linkage fits with no issues. Also, no driveshaft work is needed! The Turbo 499 shifter linkage was spot on.
Exhibit A:
Drivetrain
-NP229
Interior
-Custom console
-Custom dash
Body
-Wide Trac flares
-Maroon paint
-Custom woodgrain
-31" or 32" tires?
The engine arrives!
Behind the dash...
In with the new...
