Re: New Dual O2 sensors, 76 CB360, the Pig
crazypj said:
That's pretty cool.
Are you still using 65 primary main jet and a smaller pilot?
Fluctuation is due to the voltage measurement, only really reads from about 0.1v to 0.9v but usually less than 0.2v variation doesn't register so great.
The valves opening change O2 in exhaust gas, 'rich' to 'lean'
Interesting to see it only went around 15:1 when throttle opened, pretty sure VM gets a lot leaner (or richer when 'stock' jetted)
I got hold of a few O2 sensors but need the gauge, which one are you using?
Thanks dude!
I dont really understand all that electro-jargon you just put out there. But I really dont need to. All I know is that the thing works.
To be perfectly honest its been long enough I dont recall exactly what my current jetting setup really is.
After looking in my big-ol-box-o-jets. ..
I might have 41, 62, 110, stock needles, soldered (downsized) primary nozzles, drilled.
But after the ride I just took. It goes pretty rich upon accel.
Opposite of the garage vid. Its much different under load.
The 41 keeps it from dying on decel to stop. Due to the 62 and smaller nozzle.
I really believe the biggest problem lies w the taper on the needle. I need to find a tiny lathe so I can start making needles.
Just so ya know. the numbers remain virtually identical swapping between stock filters/boxes w the K&Ns needing only a minor tweek on A/F adjusters. The big difference is the K&Ns let her lean out a bit above 6k. = giving better performance. Under 6k I cant see any difference.
Im gonna send you an email later this evening.
