You can fit mirrors direct to bars and fit a plug so it will look more 'race professional' (check out GP bikes, they mostly have a some bar rather than long plugs, less chance of damage if it falls over)
CrazyPJ Do you know what the engine bolts to frame should be torqued at? I really don't know what else to really check on this bike front end. Figured I would at least check the torque.
Does. It vibrate if you just sit there and hold the rpm up high?
You can pound a solid steel bar into the handle bar or fill it with lead shot to reduce the vibration . . if the vibration is horrible this will not fix bit .
If the engine bolt but takes a 14 mm or 9/16 wrench then you can torque it to 28 ft lbs . . you can. Torque the axle not to 60.
Thanks for the torque picture. I will also check to see if the vibration happens at a stand still with high RPM's tomorrow. Thats a great question, I haven't checked that.
