This amusing little Yamaha Chappy headlight was one of the first things I picked up for this build. Never mind the useless 6V sealed beam and useless interior volume, it just looks so damn right...
It was always going to be fussy to mount. The 43mm XR forks have this necked-down section, presumably perfect for use with the standard XR rubber-band headlight/numberplate mounting scheme, but otherwise incompatible with any other clean clamp. My tank clearance is (ahem) minimal, so the headlight mounts needed to be slim; no funky hinged universal mounts with layers of shim material.
I like the
LSL mounts, but they seem hard to find and crazy expensive. I went with these cheaper versions from Amazon:
Unfortunately, the clamps are too close together to fit anywhere except right above the lower triple-clamp, making the headlight way too low. Also, the ears themselves are too long, pushing the light too far forward. Lastly, with the clamps in one position, the ears are wider than the fender (mad spacers required to mount the light); mounted the other way, the ears were just a bit too narrow (requiring der bendernator action). Well, at least the clamps aren't without some merit, so I just had to jigger up some new arms...
Stayed up too late re-learning basic CAD, churned out a half-dozen cheezy designs, then trotted down to my local waterjetter this morning:
The arms needed an offset bent into them, and additional locating holes for the weird little Yamaha mounts, but otherwise the works came together very quickly.
The arms are taller, to span the necked-down fork tube section, and they keep the light reasonably tight to the frame.
Aesthetically, the light would look better mounted lower, centered between the upper and lower triple-clamps. Practically, the high(er) mounted light should throw the beam past the full-size fender a little more effectively. It also leaves room for a natty little toolbag, bedroll, oil cooler, and/or laser-guided potato-cannon... Stay tuned.
