Finally got around to attacking the electrical. When I removed the electrical to strip the bike it was in bad shape. A lot of connections just staying together and at some stage some one had done a hack job trying to remove the old wires for the electronic start. I decided to do a total rewire of the bike, not only because I will be trusting my life to her, but also an effort to understand how it works. I still don't have a wiring diagram for this bike so I traced out every cable and drew one up. It might look like a 2 year old with a crayon did it, but coming from a commercial electrical background it made sense to me.
I started at 9am on saturday morning and didn't leave my shed till 1:30am sunday, good times. I soldured the last connection at 1am and turned the ingnition on. To my frustration the head light, indicator & nuteral LED, and right front indicator wasn't working, and the break light was constantly on. At that stage I was in no frame of mind to investigate, so like a zombie I packed up and staggered to bed.
The following Saturday I did some fault finding. I saw right away a a connection I forgot to soldure, once I did the head light started working. I tested the LED's, indicator and front break switch and it turns out the components them selfs are faulty. So it's safe to say I was pumped that, for my first attempt at wiring a bike from scratch, I only missed one cable and the rest of my wiring is fine.
I purchased a tiny Lithum Ion battery roughly 1/4 the size of the original. This allowed me to fabricate an end plate for the battery box and put my battery, ignition, relay, fuse & engine stop switch inside with the regulator mounted on the outside. the original battery was so big it actually pocked out one end of the battery housing.
I managed to hide all of the cables with the exception of the stuff at the front forks. I left all cables that go to the handle bars with extra length and coiled up neat behind the head light. I did this because i want the option of putting a flat bar on in the future.
If any one wants a copy of this diagram PM me and I'll draw up a neater copy and email it. Note it is for kick start and doesn't yet have an engine stop switch.
