Author Topic: 1970 CL450 (Portland, OR)  (Read 579 times)
Offline Subaruski
« on: Dec 13, 2018, 15:03:40 »
1970 CL450, third owner with 12k miles
VM32 Mikuni Carbs.  Will include Uni air filter cleaner and lube
Pamco Elec Ignition.  Will include original points
Dyna Coils w/mounting brackets for factory like fitment
Charlies Place 4.0 Type Regulator/Rectifier. Will include factory parts also
Hagon rear shocks
H4 Head light
LED rear turn signals. Will also include factor front and rear turn signals
New OEM Honda risers and Renthal handle bars
New modern controls
New clutch lever, brake lever, and throttle
Aftermarket Lucas tail light Will include original also
Factory CL450 headers with thermal wrap and aftermarket mufflers
Two original keys included
Clutch rebuilt summer 2017
Front suspension rebuilt and new gaitors fall 2017
New chain and rear sprocket fall 2017
New brakes fall 2017
New lithium battery spring 2018
New Kenda tires spring 2018
New clutch, throttle, and brake lines spring 2018
Oil changed fall 2018
Turn signal relay needs replacement and will include new relay with sale.
Factory gauges not currently on bike but will include with sale along with brand new speedo/tach cables
Wire harness could use some cleaning up but is currently 100% functional. I may have a brand-new harness I will include with sale.
Extras
Front and rear wheel All Balls bearings
Steering neck All Balls bearing
Full service manual
Brand new wiring harness
New tach and speedo cables
Clear title in hand.
$3,000 obo
« Last Edit: May 02, 2019, 16:55:05 by Subaruski »
Offline Subaruski
Re: 1970 CL450 (Portland, OR)
« Reply #1 on: Jun 03, 2019, 14:47:18 »
bump.
