Wow , thanks for all the great feedback.
The headlight has to move down and back cuz it just looks wierd where it is in the pics. and it also fouls the clutch cable routing.
The fuel filters I picked up at a swapmeet a couple years ago, along with the fuel taps. dont know the brand, but i've seen the same ones at the local napa. I cut and welded shut that silly crossover tube. wanted to be able to take the tank off without spilling gas everywhere. welded in 2 pipe thread bungs, and moved them away from the carbs. the plan is to run a set of keihin smoothbores with k&n filters like I've got on my 750. The cr's are a lot bigger than the stockers. I was afraid that the original petcock would be too close to the carbs, and I didn't like how short the fuel hose was. hardly any room for filters unless you used one of the small 90 deg. filters.just have 2 taps to forget now, 1 on each side.
Totaly agree on the longer shock idea. the hagon shocks on my 750 are for a later dohc 750-900, and these will probably
go on here , which gives me an excuse to buy a set of cool piggyback resevoir shocks for it.
The seat foam is only temporary. just stuck on with tape to help me figure out the layout of the seat-tank-rearset-bar location.
The front part of the seat still needs a piece welded in to cover the bolts that hold the tank on.when all the welding is one, gonna polish it up and have a proper leather pad made.
I spent the last couple nights working on the footpeg mounts. when all the welding is sort of done, to, as much as is possible with the bike together ,it gets stripped to the bare frame to finish welding. cant get the tig torch into a lot of places with everything in the way
Gary
